j-z wrote:youre wrong about the same amount of air getting pulled in whether you have 150 hp or 300 hp. its not the same. if it was then you wouldnt need to get a different maf from a car that flows more air. and your whole fuel setup is just whack. go one way or the other.
I wasn't going one way or the other, I was just trying to get some informed opinions. Its a learning process.
Quote »to simply lower base pressure would assume that the pressure would raise from that base pressue on the same linear scale as it would from the stock fuel pressure. It also assumes that the 370 injectors would perform on the same linear scale as a 270s. Which they don't. [/quote]
Don't hacked maf's basically use the same timing map? I mean the only thing that's changing between the two is the fuel pressure, no? So wouldn't it be the same as a hacked maf setup except w/ altering airflow signal, its altering fuel pressure? With the stock ecu on hacked maf, isn't the pressure still going to increase linearly on the 370's as it would the 270's just more fuel getting dumped?. The only difference this time around w/ the fuel flow which has been bumped down to compensate for the larger injectors? I'm sure I'm horribly off, I just don't see why this wouldn't work. Probably because its too easy.
