Ceptos »
https://forums.nicoclub.com/ceptos-u840.html
Wed Oct 09, 2002 3:30 am
heh, true, when aluminum oxidizes it produces aluminum oxide, and when iron oxidizes it prodcues iron oxide. but one thing that you forgot, aluminum oxide forms a very thin layer on top of the aluminum it oxidized from, and prevents the aluminum below it from oxidizing any further. aluminum is also a very reactive substance and forms a very solid bond with the oxide, so this coating does not disolve off and does not flake off under pressure, it is the reason that aluminum stays metallic while metals such as iron turn a brownish color.
on the other hand, iron oxide forms a very flaky coat on top of the iron, and is easily brushed off to oxidize again and cause pitting, also the particles being flaked off.
and if you are talking about a solid iron block, not steel, i am close to certain that aluminum is stronger than iron, ill look into this a bit more and see what the expansion and tension factors are.
im not trying to prove you wrong or anything, just friendly argument =)
