Why owner's manual says not to drive >50mph w/ full spare?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
I've got the full-size spare tire on right now. I'm wondering why the owner's manual says to not exceed 50 mph. I can understand that if I had a donut or something, but assuming a properly torqued (98 ft-lb) full size spare is installed, can't I go above 50mph? Or am I misinterpreting the manual, since this warning is under the "TEMPORARY USE ONLY spare tire (if so equipped)"?
The owner's manual states that the temporary use spare is U.S. only, yet my car was purchased in the U.S. and I have a full size. Was it a factory option or something?
Innovazn
Car: Yellow 1998 Nissan R34 Skyline RB25DET 5 MT - Current
White 2012 Nissan Altima Coupe 3.5SR 6MT - Salvage (T-Boned at left turn)
White 2002 Nissan Pathfinder LE - SOLD (blew the engine)
Towncivilian wrote:I've got the full-size spare tire on right now. I'm wondering why the owner's manual says to not exceed 50 mph. I can understand that if I had a donut or something, but assuming a properly torqued (98 ft-lb) full size spare is installed, can't I go above 50mph? Or am I misinterpreting the manual, since this warning is under the "TEMPORARY USE ONLY spare tire (if so equipped)"?
Temporary tires. I would assume they mean the donuts smaller cars carry and im assuming the manual has been done generically for all nissan rides and they just never bothered to change it
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
wow those must be cheap cars that you only get a donut for a spare tire, wtf are you gonna use that for? you eat it and its gone, i guess thats good if you get stranded.
The temp spare is probably not a full load-rated tire, to save on weight.
miamiheat3332
i think it actually is, if i recall correctly its the same bridgestone tire that came stock with the car.
SBK03SE
Car: 03 Pathy SE RWD Fully Loaded
Mine looks stock sized. The rim ain't purrty though ;)
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
IIRC, the "full-sized" spare on my 2001.0 PF was NOT the same as the four regular tires. It's a little smaller and less aggressive
tread.
Towncivilian
Chuck Tribolet wrote:IIRC, the "full-sized" spare on my 2001.0 PF was NOT the same as the four regular tires. It's a little smaller and less aggressive
tread.
Mine is identical in terms of tire spec (whatever the P255... is) with the other tires, and looks about the same size.
esy
Car: 2002 Nissan Pathfinder SE 4x4
i believe it's mostly due in part to the fact that the spare is not normally torqued down to spec and the difference in wheel. i think my spare steel wheel is slightly different in wheel width (maybe a 0.5" narrower, but i'd have to double check), and if the width is different, i wouldn't doubt it if the offset was slightly different too.
if the wheel is exactly the same, then i'd put it more on the fact that the wheel isn't properly nor accurately torqued down (torque range is 87-108, but our shop always errs on the higher end of the torque range when given a range), which can result in a "wheel-off" situation and can cause some serious damage.
if you rotate your spare in and out in your rotations (like i used to on my WD21 when i had all matching wheels and tires), then you can drive as fast, as you please. you can drive normally even if you don't do that and torque it down properly.
asnorton44
Car: 2001 Infiniti QX4
Mine is the same the same 17" rim and tire as all the wheels.
Innovazn
asnorton44 wrote:Mine is the same the same 17" rim and tire as all the wheels.
ditto, mine all matches up, when i got new rubber for my car i changed it as well (old spare was bald)
GRNMACHINE
Car: 1999.5 Pathfinder SE 4x4
My spare is the same Bridgestone as the original 4 tires. Mounted it up and was using it last few years for winter.
