Why no 120V power inverter in 2016?
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
jkm3093
Car: 2018 Infiniti Qx60
2014 Nissan Pathfinder Platinum
2004 Pathfinder LE
We bought our 2016 QX80 without even considering there was no built in power inverter as we have it in our 2014 Pathfinder. I downloaded the 2015 QX80 FSM that shows it was included then. Anyone know why it was discontinued?
jkm3093
2004 Pathfinder LE
Hmmm - It doesn't seem like there is much activity on this website.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
There's plenty of activity, but only if somebody has an answer for you. I don't.
jkm3093
2004 Pathfinder LE
Fair enough. As I like to contribute to forums, I'll investigate the answer myself & report back.
jkm3093
2004 Pathfinder LE
Well, it seems even the Infiniti dealership cannot answer that question. The service manager guessed it had to to with trim level, but we just traded our QX80 for a 2018 certified used QX60 at the same dealership with top trim level and that doesn't have 120V either. I guess they just did away with it. Bummer.
VStar650CL
Technical Expert
jkm3093 wrote:
Mon Jun 28, 2021 6:29 am
You can always DIY it. You can get 2kW from Harbor Freight for a lot cheaper than the factory accessory, and that lets you add covered marine outlets anyplace in the car that you like.
https://www.harborfreight.com/2000-watt ... 63429.html
mdmellott
Car: '13 Kia Soul+ 2.0L AT
jkm3093 wrote:
Mon Apr 19, 2021 6:14 am
Follow the money. Infiniti's failed attempt to capture the European market (they finally pulled out in early 2020) would have required a 240V/50Hz inverter and that would cost the company more to maintain another expensive part offering on an already anemic profit margin overseas. Margins were not much better in the USA either, so dropping the 120V/60Hz inverter altogether makes sense from an economics point of view.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
