If you're sure it was fuel, and not something else, like water droplets from the catylitic converter, you need to stop driving it ASAP. You need to replace the soft lines connecting the tank to the hard lines, most likely. Either just comming apart, or crushed under a hose clamp.That1Guy wrote:I wounld't jump the gun and say my fuel pump is going dead. But your tip did help. I prime the fuel line a few times and then started. Took about 3 seconds to start up. Still to long for me. When to check the rear and found fuel dripping. Stopped after the car was warm up. Next find the leak and hope it easy to fix.
This is, of course, true too. But if he's actually got gas on the ground, that's priority no. 1, because it could easily end in firey death.blkvrtswp wrote:I would check for bad fuel injector o-ring(s) leaking fuel into the cylinder after the engine is shut off, causing low initial fuel rail pressure on startup. This can also reduce your MPG, and cause raw fuel to come out the tailpipe. Also check your oil (sniff dip stick) for fuel smell - that causes spun bearings - and change it if necessary.
O-rings are dirt cheap from the dealer, relatively easy to swap out. Hope this helps.
no no no, I didn't mean that.That1Guy wrote:It leaks near the gas tank area. And I have a brand new cat on right now. Switch back to old one when I have time.
If it's the hatch that your profile says, then it's on the right (passenger) side of the trunk, to the side of the spare tire well. It's a beige panel screwed down. Once you get it off you'll be looking at the top of the fuel tank, which also has a hatch, which you do not need to remove (unless you did all the O-rings and hoses, and determined that you actually had a bad pump, which doesn't sound like the case). Coming up from the hatch on the tank are short hardlines/barbs, which connect to a hose that goes over the front of the tank. I believe you can simply thread a new hose forwards, and attatch the other end from underneath the car, if you attach the tank end through the trunk, and there's no need to drop the tank or anything.That1Guy wrote:Ok, my car usually in the garage. I have a 3.5'' exhaust that doesn't look close to the drip. The drip smell and feels like gas. I never seen the hatch for the hardlines before but I'll take another look.
I was just saying if you start the car it and look, you can think there's a leak, because the cat blows water out the exhause. He said it stopped when it warmed up, and that's what the cat does when it heats up, it blows out invisible vapor instead.blkvrtswp wrote:Ah, I thought he meant the fuel was coming out of the exhaust. I agree with MM - you have a leak in the fuel lines. Replacing the rubber lines from the pump to the hardline can be a PITA, but at least it is cheap.
Hoses can also leak when it's just cold outside. I was recently playing with another problem, but it involved repeated priming, and I started smelling gas. Went and looked along my fuel rail, and all the hoses where wet, but they never normally leak. Tightened them up, and now they're fine in the same temp.That1Guy wrote:So my problem might have been a few things. My fuel pump die yesterday, (replaced), and found a vacuum hose disconnected so some unmetered air got through. But fuel was leaking. I should raise some hell because I took my car in to get my EGR solenoid replace and smog. They charge me $400 for 3 days of labor and diag. When it took them 1 day to do. My vacuum lines aren't even routed right.
This is why you should get trained to be a tech my friend! This is the fabulous world of "book time." You get to charge what the book says it should take you to do the job, not how long it actually takes you to do it. When I was at (some major technical school that happens to share its achronym with Urinary Tract Infection)That1Guy wrote: I should raise some hell because I took my car in to get my EGR solenoid replace and smog. They charge me $400 for 3 days of labor and diag. When it took them 1 day to do. My vacuum lines aren't even routed right.
I do take automotive class. Matter of fact it a GM training facility.Their flat rate by the books hours and their pulling a number out of your a**. He said 4 hours of diag. And order the part then 3 days later put the part in to find out the wrong part came in. Week later new part came in install then smog. I only see at most 2 days of labor. I would have prefer to have done it myself if I wasn't so busy with school and work. I can look up the total labor time and bet he overcharge me.SX APPEAL wrote:This is why you should get trained to be a tech my friend! This is the fabulous world of "book time." You get to charge what the book says it should take you to do the job, not how long it actually takes you to do it. When I was at (some major technical school that happens to share its achronym with Urinary Tract Infection)one of my instructors still carried around the ticket from when he did over 40 "hours" of work in a single 8 hour shift. That's the only way for techs to make any money in this day in age. Don't hate the playa, hate the game...
...yeah totally went there, totally justified
