Because after I do the alignment A, they still not fixed my problem - still pulling aside.
Yep, I can see why. On alignment B (initial), the toe measurements are different. negative are toward the center of the car, positive is toward the outside. So They are both pulling in the same direction, left. They should both be positive or negative to counteract each other.
Since both shop are Nissan's service, I am sure they use the same machine (both have John Bean logo).
Yes and no. I don't know if they have a requirement to buy a specific machine, set by Nissan standard. Do you know what models both places use? Normally, I'd say compare to the same machine only (this is what we do for horsepower dynamometers).
In my opinion, if both shops use the same machine and procedure, it should get the identical result (at least the difference is very minimal) but not like this..
Yeah, definitely not right.
After shop A do the alignment, shop B say the toe is out.It is somehow confusing, which shop is correct?
I think shop B is ok. The maximum on the toe is 0.08" (so 0.09" is out of range). Shop A has a difference of 0.07" on the front, which will make it pull to one side.
BTW, Do you have any idea how my rear toe is so out of spec? Does that imply it might be a defect when manufactured?
Actually, nominal measurement is +0.118" (+/-0.158"), so both are within spec tolerances. They are not adjustable without a shim, which your alignment shop could install if you wanted them to.
Here is where I am getting my numbers.
http://www.nicoclub.com/FSM/ve...d.pdf
