why is this latch here?
93sleeper
Car: S13 project
There's a latch at the front of the manual sunroof on my '93 SE. Does anyone know what it's for? It seems completely useless since the hinges hold the sunroof on. Thanks.
S14Life
Car: b5 s4 stage 3, 2001 pathfinder, 91 s10
Well if it's like mine which I think it is, it keeps the moonroof from folding all the way up. You see, on the handle which you grab to put the moonroof up, on either side there are buttons, you push both puttons in and you can pull the handle out and if you undo the latch in the front you can raise it up 90 degrees.
Cyberkreig
Car: 1993 Nissan 240SX SR
If its like mine, You flip that latch. Then disconnect the handle in the back using the two black buttons.
Flip the sunroof up to 90degrees and then slide sideways. Way-la. removeable.
S13ChucKAT
Car: asd
Yeah.. thats how you remove your sunroof..
the rear latch that pops it open 15 degrees, theres 2 black buttons on the left adn right of it.. push both those in, and you can pop the latch out.. then in the front theres a little knob/puller.. pull it to the left, and it releases the front of the latch, then lift up 90 degrees, and pull to the left. your sunroof is now off.
Silvia2b
Car: 95 240sx se / 07 G35s cpe / 2009 G37s sedan (rear-ended R.I.P.) / 19 Q50 rs400AWD
yeah but why does it need to be removeable? I always used to wonder if there was a reason.
corn322
Car: 1993 240sx
so your passenger can stand up out the sunroof and shoot.
s13EastTN
Car: 91 s13 hatch, 95 Honda Civic
Because it can't slide back without hanging over the glass/possibly being hit by the windshield whiper. Also, it is the lightest/cheapest way to have a sunroof, and its the ONLY way I will have one, considering the small amount of weight added, by just having to pull a couple clips and such.
93sleeper
Car: S13 project
Ah, that makes sense. Thanks!
