This thread is the only one that relates to your issue, but unfortunately everybody in the thread misdiagnosed the problem as the blower motor
resistor, when the auto climate control system uses a fan control amplifier (see its location
here). This is a more expensive, but still failure-prone part. I believe you should try replacing this part first. You can give Rob a call at 1-866-742-0297, he should be able to provide you with the best price for an OEM part. Have your VIN ready.
You may wish to change the cabin air filters while you're replacing the fan control amplifier if they haven't been changed within the past two years. No need to get OEM filters here, aftermarket ones from your local auto parts stores are cheaper and will work just as well.
