klh6686 »
https://forums.nicoclub.com/klh6686-u16180.html
Mon Nov 13, 2006 8:55 am
do you know if the ecu has been chipped? you might want to crack it open, because the ecu will blink when you have a bad chip. Also, check the orientation of the chip (the notch on the chip matches the notch on the ecu. If the notch matches, you may need a new stock chip burnt by someone reliable (I have some, Carl H should, just let one of us know)
