adren77 wrote: If you turn off the AC button, the auto mode is still ON, which is a good thing, but I'm tired of having to worry about it all the time.
no you can't ( I agree it's dumb)
What's dumb is many of the comments posted in this thread about "having to worry about it all the time," "have the auto controls emit heat...without clicking over manually", and "I often turn the A/C off...but sometimes I forget and it is annoying."
One would think some of you have to go through a ten page procedure to set the Climate Control as you want it to operate, and then you can't sleep at night because of it.
Set it to AUTO and turn the dial to the desired temp and forget about it.
Or if that's too much of a hassle for you, then you can say the command if you have NAV - oh, but you have to push a button.
AC on? - push one button to turn it off.
Heat not blowing in your face, push one button a few times.
AC running wastes gas? - buy a Prius.
Get a life and stop sitting around thinking of silly reasons to post on a board.
