no_se7en wrote:my TT has the same problem. It smells like fuel in or out of the car when started and goes away, but no smell from the vents. The previous owner took it to the shop and said it was some kind of a fuel sensor. I don't know but mine won't pass smog because of that and i live here in california.
The only OEM fuel sensor is on the fuel temp sensor on the fuel rail, and it's sealed off from fuel flow.
OP and all, unless you have a faulty gas cap, your most likely source of fuel smell is going to be the hose clamps. In colder weather, the hose shrinks, the clamp does not. Tighten all fuel hoses and your smell will most likely go away. Do note that not all clamps are easily accessible.
