silviaNE »
https://forums.nicoclub.com/silviane-u4871.html
Sun Jun 01, 2003 10:31 am
DO YOU HAVE YOUR CAR LOWERED MORE THEN 2 INCHS, AND DO YOU DRIVE ON A LOT OF ROUGH SURFACES (IE POTHOLES, GRAVEL, UNFINISHED ASPHALT.) If so, check the bodies of the shocks, do you see any leakage? when a car is "dropped" or ridden on rough surfaces, the shock seals will tend to deteriorate faster and cause a harsh ride or squeak. Check your bushings also. Espesically the top strut mount bushing. Also check to make sure all bolts are properly tourqed. I hope this helps. Lets try to help each other. I only like and drive nissans, but am willing to help anyone.
