Why is My SR Running So Rich?
240dreams
Car: 240's
I really dont understand why my car is running so rich. Im getting some horrible gas mileage - about 14-15 MPG. I smell lots of fuel during idle and I get a strong stench after a hard pull. The car also backfires all the time when decelerating from 2k-1k rpms. I know my atmos. BOV plays a role here. Its just crazy how similar 240's with similar mods get almost double the gas mileage Im getting. My car is also untuned. Does anyone know if tuning will help with my situation?Mods:FMIC, BOV, 3in exhaust to Stock Exhaust, Walbro 255, and others that arent significant.
DriftBandit
Car: this is my 3rd 240sx
Maybe your FPR ( fuel pressure regulator) is bad, Mine was and it was sending too much fuel pressure to my injectors.
What motoe are you running,S13 S14??
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
well maybe it's just our area cuz i got the same issue
fuel smelling car, bad mileage...eh w/e
240dreams
Car: 240's
s13 SR. Its on the stock Fuel press regulator. Is there anyway i can check to see if its bad?
MainEvent212
hm...i kinda like running rich...backfire
got2b240
Car: 91' RPS13 = GT28R, 525cc, Z32 Mafs & SAFC, Blitz EXST & FMIC, Silvia VLSD
yeah same here, I set everything I know correctly, and I smell fuel in my car after getting on it. I think it might be my 02 sensor, but im not sure. I should ohm it out and see if it still works
Cyberkreig
Car: 1993 Nissan 240SX SR
Same problem here. No tuning. Walbro pump. My o2sensor didnt work, but now it does.
tons of backfire action.. man tailgaters backoff.
240dreams
Car: 240's
did changing the 02 sensor help out at all?
DriftBandit
To check if your stock FPR is bad hook up a fuel pressure gauge to your inlet fuel hose(the one with the fuel filter) and check the pressure. I believe it should be around 35psi at idle and at WOT(wide open throttle) it should read around 44psi. To check WOT fuel pressure just remove the vaccum line to the FPR when you are at idle.
hope this helps.
Doomed2Walk
Car: 2005 Subaru Impreza WRX STi WRBP on gold
I believe the correct term for the effect of running rich and left over fuel igniting as it hits the air is called afterfire. Sometimes I get a loud popping noise sometimes when I take my foot off the accel after WOT, but I can't get behind my car to see if it's afterfire and it seems to happen randomly.
creophus
Car: 240SX SE & 200SX
I'm having a similar problem. I had the car tuned on a dyno, but then I stored the car for about 5-6 weeks with the battery disconnected. Now it backfires again.
SpeeDDrifT
Car: drive. drift. drive....um drift...SAFELY. k
same problem here.......backfire....afterfire.......whatever the name of it is ...i'd like to get rid of it before i do it in front of a cop.
MainEvent212
backfires w/ flame come from having no CAT...the CAT will filter the raw fuel and it wont ignite, just pop...if you want it to stop, then get a car that isnt tuend for performance
Cyberkreig
In reality, the question is metaphysical. Why is my SR running so rich? Why does the Sun rise? Why are we here?
Somethings simply are.
240dreams
Car: 240's
let me change the question to - Why is my SR running so "abnormally" rich?
nismostate
Car: all sorts of motorsports
found this site that might be interesting for everyone. learn how to check the o2 sensor.
http://www.shotimes.com/SHO3badO2sensor.html
Jala47
Car: 1999 Nissan Altima GXE
make sure the BOV is on correctly and everythings screwed on tightly. My friend had a lose screw in his and it was causing the same gas mileage problems
