Why is my seatbelt light on?
mss5413
Car: Nissan 240sx
Hey guys, my drivers side automatic seatbelt seems like it has a loose connection somewhere because I have wiggled it and the light goes off and then I let it go and the light goes on, it sometimes blinks too. All of this happens when the door is closed and the seatbelt is in the latched position or whatever it is called. Any suggestions or ideas on how to approach this problem would be appreciated. Thanks.
Zyphar
Car: 91 S13 5spd ! Stock, well almost stock.
i had this problem before but now i got it fixed by the dealership beacause the seatbelts are under warrenty.
But to fix the problem, make sure that the seatbelt is all the way down into the latched position. even if the motor stopped already, just push it down with your hand and it should go away.
If not, take it to the dealer.
Twinchy
Car: Peg leggin 240sx
hey zyphar what part of so cal is that in your sig ?
nismojunkie
my drivers side seatbelt doesnt even work and the light goes on and off randomly
