ghettoslide »
https://forums.nicoclub.com/ghettoslide-u18248.html
Thu Feb 09, 2006 6:16 pm
This on is easy. Your motor is about to blow up. She did good to 5500 rpm, well that is the limit, when you have oil in it. Can you walk with no blood in you. Regardless stop driving, pull the motor begin immediate and needed rebuild befor the damage goes to far and you need a block too. You may not be "knocking" it could be piston slap in which case you broke a wrist pin. Well hell, A wrist pin holds the piston to the rod. If you break it the piston "floats" and the rod bangs into it over and over. If you broke a rod, same story its' a matter of time before it punches a hole in the block. Park it, build it,. Use oil next time, and check for leaks allways every time you back up from a parking place always it's true car guys religion. oil is blood. Players **** up, don't be afraid to ask for help. Next tip: Get a full bus pass it may be cheaper than paying for each ride your going to need it.
