Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Aug 28, 2008 9:03 am
Moving to 240 tech.
Are all of your dummy lights staying on? Or just the brake light? I ask because the brake light pulls its power from the source as the other dummy lights. The fluid resevoir switch and the e-brake handle switch are both ground complete switches. The power source is a switched source that all of the dummy lights share, so if one is on, others should be too.
As for your avc-r, make sure you tapped a switched circuit to power it, and not a constant.
