Hijacker wrote:the TCU has no bearing on the seatbelts. It almost sounds as if someone has messed with the wiring behind the dash. I would recommend pulling the gauge bezel and taking a look to see if there's been any cuts in the wires.
Also, check to make sure that someone hasn't messed with the door latch mechanism inside the door. There's a switch that completes a circuit to make the seatbelts go forward. If it's stuck in the on position, your seatbelts will stay forward because the car thinks the door has been opened. Disconnect the switch and see if your seatbelt retracts to the default poistion towards the rear of the car.
nah its not the tcu i was talking about, its the seat belt controller. and the seat belts aren't stuck in one position, its just that they will only work when the key is turned. i'm gonna put a different controller in there and see if it helps anything.
mr.grimlock wrote:...if its a r200 carrier, as long as it's designed for it, then you can put in any limited slip you want in it. whether it's a 1 way, 1.5 way, or 2 way it shouldn't matter.
yea i found out today that since i have hicas my carrier is not the same and i will need to use my other one. but i think i'm going to put my stock axles in until i find a set of j30's cuz right now i just wanna get that diff in there
