Why is it so cold?!?!!?!?!?
Want to talk about non-Nissan cars? Here's the place!
Healing
Car: '98 Nissan 200SX SE-R
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
WTF???
Mr1der
you're supposed to leave it in the foil, duh!
base9se
Car: '95 240sx
Some people just don't ever read directions.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Hey, base9se. Do are you aware of the explanation for that paradox in your sig?
silkk
Car: 94 B13
89 S13
07 S2000
It's an illusion!
base9se
Car: '95 240sx
MinisterofDOOM wrote:Hey, base9se. Do are you aware of the explanation for that paradox in your sig?
here's an explanation.. base9se-i-m-calling-you-out-t90235.html
Mr1der
luckily for me, I don't give a damn about it!
boya!
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
There's another version of that that I've been trying to find, but I can't. It's even harder to tell that its not quite right. Even the math won't give it away unless you calculate it out to three or four decimal places.
Healing
Isn't it cause the slope of the triangles is slightly different between shfting the triangles around to form the second rectangle?
Mr1der
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
If you were able to recreate it on a large enough scale, you would see that at the point where the triangles run directly next to eachother in the second (smaller) arrangement, they actually overlap. There is a minute amount of overlap, but it's area is large enough to reduce the overall area of the larger rectangle and make it appear as though it has shrunk.
In the other version I have seen, the loss of area comes from the top and one of the side edges, and is so minute it is nearly undetectable.
Oh, and 1der...
Yours may be bigger, but mine's real.
Return to “Others”
