I have a multimeter. but ???? i've tested things like maybe bad grounds and resistance, and replaced the lower harness, and tried to buy new relays. but I just jump the relay with speaker wire. and the it will run, its the only thing i can get to work. and for some reason the last three people who have owned this car couldn't get the battery to stop draining( the alternator works fine), i cant figure it out either i just take the terminals off every time i shut it off.
But the first the time i checked out my ECU it read 55, And I was confused because I thought the car idles fine even regardless of jumping the relay ,but my major problem with the car was that it would bog when i tried to accelerate. I wanted to test the ecu again just to make sure so i let the car idle for about three minutes then reved it up slowly and then shut it off and tested the codes again and it read 34. so i know i have to replace the knock sensor ( THANKS for the tutorial on how to take it off without removing the manifold ) its one of the only sensors I didn't replace.
I dont think thats gonna fix the relay ,But it may be drivable.
but as far as the relay not working it never happened until i replaced the motor so ???? but its the third motor that's been in it i believe.
I agree with you though i need to get a consult cable.
