You have a very small window of low power in the Ca's power band. Spraying nitrous at say 1500 rpm will not be smart. With the properly matched turbo and functioning fuel system, i'm pretty sure you can work through your low end power blues. You can always build a stroker motor off the CA20 powerplant.8ggalant wrote:please its nitrous....sorry i hate that...anyway...i was THINKIN about sprayin on my ca when its done....i doubt i will tho
c-rad wrote:if you want low end power, why did you get a CA to begin with?
Its called properlly sizing a turboMyetball wrote:A while back I saw one of those Sunday morning tuner shows that featured a modified Z32. Boost came on at over 4k so they set it up to spray until the turbo spooled. Turbo lag was a non-issue and the thing was wicked fast.
To play devil's advocate here, as power goals increase you do eventually leave the world of "properly sized", low-rpm spool turbos. I seriously can't see a 450HP CA pulling hard from 3200 RPM without something to fill in the bottom end. Using a supercharger with a bypass valve isn't much different in principle to using NX. There are some impressive twincharged MK1 MR2s around, not to mention Nissan's own factory MA09ERT.81na ZX wrote:Its called properlly sizing a turbo
I think I haven't seen high-power CA18DET pulling good from rpms lower than 3000-3500... Saw a thread where you said:"From 1000rpm to 3200rpm with a real decent turbo, this engine moves at its own pace unless you have a standalone and you advance the timing between 1000 and 3200rpm."In my opinion this range is very important for city driving. I'd like to help the engine to get there fasterboost_boy wrote:You have a very small window of low power in the Ca's power band. Spraying nitrous at say 1500 rpm will not be smart.
1) I got CA because a got a car with CA18DET 2) I like CA3) I will continue to tune CA4) it's the only affordable Nissan engine in here5) I like CA once againc-rad wrote:I don't get the whole "I want more low end on my CA" questions. I mean, if you want low end power, why did you get a CA to begin with? If you want a low-end torque monster, turbo the KA. If you want a happy high-revving top end puller, get a CA.
Why is it any time we talk about speed and horsepower we have to compare everything to 1,000+ hp 12 second and under Supras and Skylines? Yeah you can properly size the turbo on a CA to get 2500rpm boost but it's gonna be a stock T25 that will die out on top.81na ZX wrote:Its called properlly sizing a turbo
For example: Dyno Queen Supra A makes 1200 hp... from 6900 to 7500 on lets say a T91. Runs 12sBPU+ Supra makes 450hp from 3400 to 7500 on like a T61. Runs 11s.
So you gotta ask yourself, do you want a preatty dyno, or a fast car? Properally sized turbo will give you a fast car. Super huge turbos will give you gobs of power, gobs unuseable power.With the right turbo, you won't need help to spool it from n2o (and I prefer NX to NOS anyway ) and you'll be faster than the car that needs the help - even after it sprays...
If you're driving in the city I hope you're not driving at WOT.Vetal wrote:In my opinion this range is very important for city driving. I'd like to help the engine to get there faster
A T25 isn't a properlly sized turbo. Its a factory specified turbo for early spoolup and so companies don't get sued.Myetball wrote:Why is it any time we talk about speed and horsepower we have to compare everything to 1,000+ hp 12 second and under Supras and Skylines? Yeah you can properly size the turbo on a CA to get 2500rpm boost but it's gonna be a stock T25 that will die out on top.
Rather than offer up these massive hp cars as examples, how bout someone tell this guy what the proper size turbo is to get good low end pull and still has good pull on top? For a mostly stock CA I doubt such a match can be found.
Spray it, SC it, live with the lag, or launch every green light at 5k+
Listen man, you can go out and experiment with nitrous if you want and let us know how it goes. I personally don't see the need for adding juice just to increase power from 1000rpm to 3200rpm. This engine's ability to rev will see you past your dramas. And if your CA is really that lazy on the lower end, then there is something wrong with your set-up. It may not be the most low end power monster, but it sure as hell ain't no slouch either.Vetal wrote:I think I haven't seen high-power CA18DET pulling good from rpms lower than 3000-3500... Saw a thread where you said:"From 1000rpm to 3200rpm with a real decent turbo, this engine moves at its own pace unless you have a standalone and you advance the timing between 1000 and 3200rpm."In my opinion this range is very important for city driving. I'd like to help the engine to get there faster
And get 11% more displacement for some 1500$? I wouldn't consider it as a sensible option
Why is it bad to spray NOS at low rpms? If the engine produces let's say 30hp (just a guess) at 2000rpm, why not add another 10-15hp on WOT ?
What you effectively want is a bigger displacement. Honestly, a positive displacement supercharger is the only thing that's going to work for you here; its the only means of introducing extra air from the get go without compromising the engine. For instance:Vetal wrote:I'll research it a little bit I need 1500-3200 range cause unless I see a BMW I drive like retiree And when I see BMW I'm usually too lazy to downshift
LOL, I pretty much said that in my post....float_6969 wrote:Can I be the jerk and tell him to get a KA? I mean, you want a really driveable motor, the KA is the one to have. Even off boost, it's got plenty of torque. If I was going to build another car, and just have it for street use, I'd have a turbo KA, no doubt about it in my mind.
