So, I built an sr20det bottom end, and am now starting to overhaul the redtop head to go with it. I brought it to the machine shop to have the valve stem seals replaced. I bought the seals from Enjuku. They are supertech seals, 6mm intake, 7mm exhaust. I was under the impression that these seals were correct for the sr20det head. However, the machine shop tells me that the seals do not fit the exhaust valves. The intake valves are fine. To my knowledge, the valves are stock. Why on earth wouldn't they fit? I looked at the valve stem seals before handing them over to the machine shop, and they were correctly packaged as 6mm 7mm valve stem seals. Springs and retainers look stock if that means anything to anyone. Are these not the right seals? What's going on here.
