Why don't my gauges work?
drft204
Car: 98 VW GTI VR6, 89 240sx Coupe
Hey I did an E to DE swap. I changed the tach with the DE and everytime I start the motor the tach does not work. I can't tell if the speedometer works because the car isn't drivable yet. And my temp gauge is always doing funny stuff like going up past the H mark.
[Translated to English by Rev D]
w0nderbr3ad
Car: 1990 240sx with ka24de swap
try swapping over to a dohc cluster.
reelyfast
Right, the cluster.
I'm not sure if you have to have the DOHC cluster and tach, but you probably need the cluster atleast, for sure.
drft204
i did get the dohc tach.. now i swapped it with the whole cluster. but nothing :S the lights don't even work in the cluster. it blinks like three times when i turn the car on but nothing :S. and my fuel gauge don't work. nothing works dammit. and after i installed the dohc cluster it had a cel. and it was always on even tho my cars not on. iunno if its becuz its not connected or anything or if it means something :S
w0nderbr3ad
check the ecu to see what codes you're getting.
drft204
how do you check the ecu? i've never worked with ob1 cars before?
w0nderbr3ad
check here
http://www.240sx.org/faq/index.html
look under reading ecu codes
