why doesn't my 240sx drift?
mikenissan08
Car: 240sx hatchback!!!
so i took out the three "anti-skid" relays from under the hood, but my car still wont get sideways, i feel it cutting loose, but then it just straightens up like something is holding it back. i can drift pretty easily in the rain. is it because i dont have lsd? or is there something else making my 240 unable to spin out?
Doya
Car: '95 240sx KA-T
Learn the fundamentals first http://www.5min.com/Video/How-to-Drift-9313
90gtpony
Car: 93 240sx hatchback
oh man this is gonna get good.
p3tchSR
Car: 92 240sx
You don't need an LSD or Welded diff to drift but it helps...
It's either your driving... or I have once snapped my motor mounts causing the engine to flex to much and not break the tires lose.
1KleenS13
Put the skirt in the trunk. No offense but your probably just getting nervous. Pop the clutch in second and let it eat.
shiftngears
Car: 1989 Nissan 240sx
lol. do exactly as 1KleenS13 says. just about anyone can do it in the rain i can. the tricky part is learning how to do it on the black top
Klits562
Car: white s13 coupe
just take it to an empty parking lot and throw all fears out the windowif your trying for your first time on the streets thats just dumb and your probably subconciously holding back
ericb382
Car: 96 s14
You have two GOOD options.
1. Bring it to a parking lot event at a local TRACK. Clutch kick the f@ck out of it
2. Sell your car, buy a civic, put the biggest wing you can find on it.
p3tchSR
Car: 92 240sx
hahaha
Klits562
idk if this will cause ur car to correct itself but check if you have a super HICAS model 240sx......... i know it interferes with drifting
chalmer240sx
Car: 1990 nissan 240sx
DRIVER MOD!!!! NO JK. id come up to the corner in first at about 25-0 miles per hour (speed and gear is determined by size of corner) faint away from the corner then throw it back into it, pull the e-brake until you feel it comeing loose and getting sideways, (dont be afraid to really rip on it) when ur pulling the ebrake have the clutch in and gas in till about red line pop that s*** and counter stear, hold it for aslong as you can. and straighten out.
Also check your tire tread, if u have barley any it could cause the tire to just spin.
you dont nessicaraly have to have suspension and a locked diff of some sort but you would be surprised at the difference of handeling from coils and how amazing it feels when u get sideways with a diff.
i know when i put my coilovers on and a welded diff in it took me from blah to holy S***!!!! lol
just put your purse down bro!!
Klits562
chalmer240sx wrote: how amazing it feels when u get sideways with a diff.\
it is ALOT cleaner and more stable
NFixed85
Car: 1990 240sx
lay into the throttle ur letting off r u because the allows the car to straighten out. ive let off b4 mostly because the roads i live on i could hurts someone. ive drift the back parking lot at my local walmart lol.
chalmer240sx
oh and if ur trying to drift to the right it wont work cuz u have an open diff try left corners
Chris28
Car: 92 s13 KA-T
chalmer240sx wrote:oh and if ur trying to drift to the right it wont work cuz u have an open diff try left corners
Open diff sends power to the wheel with the least amount of resistance. It won't matter if he's going left or right, the inside wheel will have the least load on it so it will spin.
OP: put your anti-skid relays back in, that's for ABS. Weld your diff and take it to the track.
gigabit240
Car: 92 s13 hatch -sold
98 s14 kouki -current
Na
Klits562 wrote:idk if this will cause ur car to correct itself but check if you have a super HICAS model 240sx......... i know it interferes with drifting
Na not really. I got a HICAS model and it drifts just fine. And im assuming since you have HICAS you also have an lsd but i dunno for sure.
If you wanna disable the HICAS pump then just unplug it lol. Its under the car around the dif. It looks kinda like the brake master cylinder without the cup of fluids on top haha.
Good luck sir
jonj0nn
90gtpony wrote:oh man this is gonna get good.
Haha yup..
nismokid240sx
Car: 1990 nissan 240sx s13
yeah dude if you dont have an lsd then try left turns. i dont have my lsd on and when i try and rip it on right turns it grips like crazy. Please for the safety of everyone else do it on the track or in an empty parking lot. stay out of trouble
BTP
Car: S13 coupe
you need to watch the drift bible before you do s*** in your car hahahhahahahahah what a dumbass.
her bro http://www.youtube.com/watch?v=BzlrQHJYedk
Shift_Kouki
Car: 95 Nissan 240SX SE
Or you could learn grip driving and have faster lap times... Then power slide the exits just to show them you don't need no traction on corner exit because you're THAT FAST. Or you could not do that and actually be fast for the whole lap.
But you're probably going to drift all over the place, be slow as balls, and install a giant crystal dildo shift knob in the car to complement the JDM tyte SR20 swap. God I f***ing hate people.
Justin35ll
Car: s13 coupe sr20det
dude it must be because you don't have a sweet body kit maybe you should buy one it might help
