NBP45 wrote:does your car pull to one side when you brake hard??? my car pulls to the left for some reason when i brake hard...not sure why.
A few possible causes ...
1. Leaking brake fluid on the other side wetting the rotors a bit, causing it not to grip as well, so the car swerves to the left - usually, this is a hard swerve, not just a bit of pulling. Touch the rotor on the front right and see if it feels wet or slippery or not the same as the front left.
2. Poor or damaged tires. The Goodyear RS-A is to be avoided! If you have these, change them out as soon as you can. If you have low load index tires, they may have internal belt failures (due to the car weight) causing bad handling.
3. Unbalanced tires. Try balancing the tires and doing an all-wheel alignment on the car.
4. Worn brake pads. Get them checked out and replaced if necessary. Use Infiniti OEM pads ... most other stuff does not do as well.
5. Check out the front suspension to make sure all is well with that.
Good luck!
Z
