Why dOes the clutch pedal STay down.
Redtoppeds13
WHy does the clutch pedal stay down when i push it in.
It doesnt come back up like its supposed to.:confused:
Drift Machine
Car: 1991 KA-T 240sx
Is it just not coming up, or have you worked on your slave cylinder and are trying to bleed it. Or what? We need more information on what you are trying to do.
Redtoppeds13
Im buyin a 240sx and the clutch pedal when i press it, it stays down and doesnt come back up:(
thats all i can say cause i saw the car already and was gonna take it for a test drive, but it had no gas.
EVerything on that car seemed perfect interior/exterior was perfect.
Its a 1989 240sx
specialkonrd
the slave cylinderis probably leakingits cheap to fix cost like $20 on mineto test drive, buy some dot 3 brake fluid and pour it into the clutch reservoir (to the right of the brake boost)
Nebraska240sx
for a while i ahd a 90 escort gt and one night I down shifted to hard, and the clutch would not come back out, took it to a shop cause I though the clutch went out, but after a mechanic looked at it for a while, and tried to adjust it, it finally came loose, take it to a mechanic and have it looked at and then tell the dealership to have it fixed before you buy it NOTE THE CLUTCH IN THAT CAR WENT OUT ABOUT TWO MONTHS LATER, TRY TO GET THE DEALERSHIP TO REPLACE THE WHOLE CLUTCH FIRST BEFORE YOU BUY
specialkonrd
he never said hes buying it from a dealership
Nebraska240sx
I was saying if he was, sorry you misunderstood
