rswails »
https://forums.nicoclub.com/rswails-u147159.html
Thu Feb 18, 2010 4:42 pm
Hi guys. I have manual transmission rb20det in s13.
My primary problem is one cylinder will go out after I drive my car for about 20min. I've read the engine error codes, and I have a code 21 "Ignition signal". I'm thinking after the ignitor gets hot from the engine heat, it just starts missing for some reason. If I wiggle the connector for the ignition signal wires from the ECU ( blue ones ) the missing cylinder will resume firing again. Also, if I push in on the connector, or push up, the missing cylinder resumes firing as well. As soon as I let go it usually starts back missing again. Now I've read of the ignitors going bad commonly on the rb20; do you guys think this is a harness/ connector thing, or do the pins in the ignitor get fidgetty since they are 20 years old?
It's really weird how this only happens after I've been driving about 20 minutes usually. Sometimes it takes longer for the miss to happen, but the miss never happens before 20 minutes ish.
Not sure if this matters, but my car will run for about 3 seconds after I take the key out. I can see the light for the ecu glow red for these 3 seconds, then when the ecu light goes out, the car stops running. Is this normal?
