How much would an entire timing kit be? And what all is involved with installing a complete timing kit? Maybe a write up somewhere?cheezy240 wrote:Just get a new timing set thats what I did and no more rattle
Right but isn't it possible for them to malfunction or get clogged so the oil pressure cannot build up in the tensioner? May be completely off...sx moneypit wrote:If the oil pressure is low the tensioner will not stay extended to keep the chain tight.You need to check and correct your oil pressure problem.
screw your rattling chain. low oil pressure equals destruction of engine.NICONick wrote:Right but isn't it possible for them to malfunction or get clogged so the oil pressure cannot build up in the tensioner? May be completely off...sx moneypit wrote:If the oil pressure is low the tensioner will not stay extended to keep the chain tight.You need to check and correct your oil pressure problem.
vancouverbc wrote:screw your rattling chain. low oil pressure equals destruction of engine.
