96Qowner »
https://forums.nicoclub.com/96qowner-u19561.html
Tue Feb 19, 2008 12:54 pm
Nope, entirely different. The TR bushings are a cheap easy rehab. Either buy new rods with bushings for a couple hundred or just press in new ones for under a hundred. They're fluid filled - should be easy to see if they're trashed just by looking at 'em and giving 'em a good squeeze.
But, yeah, as others have said, you'll want to look at everything - tie rod ends, upper links, third links/kingpins, etc.
I mentioned TR bushings because my car was bad on the highway when I first got it - the wind would push it all over the road. New TR bushings fixed that. You should also keep an eye out for one of Jeff Williams' front strut tower bars when he makes another batch - really tightens up steering response.
