Why does my o2 sensor have one wire
alicbr
Car: 1994.5 nissan 240sx
2013 vw cc rline
I have a 1995 s14 with s13 red top sr and can’t figure out the o2 I need please help
amc49
Car: '11 Nissan Versa
'17 Nissan Altima
Earlier ones if correct only need one wire the output, O2s make their own voltage. Later ones add a heater circuit to heat them faster to lower emissions.
PapaSmurf2k3
Site Admin
What's the problem?
Do you have a 1 wire O2 sensor and your harness is for a 4 wire?
Hijacker
Car: '92 240sx Convertible
'94 F-150
Red top harnesses have heating elements in the O2 circuit, so it has an additional 2 wires. Only one wire is actually signaling to the ECU. It's been a while and I can't remember the wire colors off hand, but you only need to connect your single wire O2 sensor to the signal wire.
