How do you figure? The car was designed to run on 91. Sure, you can give it 87 and the knock sensor will do its thing if it detects any abnormalities under load. The only way that lower octane would improve mileage is if premium fuel has too MUCH octane is not burning completely... I find that pretty unlikely.drugsbunny666 wrote:put regular octane 87 that really improves the mileage.
drugsbunny666 wrote:It all depends on the way you drive and what octane gas u put in. Dont drive crazy and put regular octane 87 that really improves the mileage. Also do another thing go get fuel injector cleaner put it in next time you fill up this will help your mpg. Good luck.
B/c thats what it runs on.fukin240 wrote:Why does my KA drink gas?
wow...ya it does..did you change the compression ratio?..do you have larger lobe cams..stage1,2,3?...did you have any head work?..lots of things come into play man..the more you mod..the less gas milage you will recieve...if your looking for gas milage..you should have bought a f***in prias...your in a semi moded 240..dont expect miricles..allso..you stated you know alot about the ka...after reading all of your questions..(that are redundant)..you should have been able to fix the issue by now...im not tryin to burn ya donw man..just tryin to show you how you are sounding....i am a newbie allso,but i dont claim to know everything...i wish you well sire and i hope you get your issue resolved.fukin240 wrote:Ok what mods would cause me to drink gas in my KA, or get low gas mileage, that has to do with the
Head/Valves/Cams/ or pistons?
Modified by fukin240 at 2:55 PM 8/3/2008
