Why does my clutch squeak?
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
No, its not because the clutch is a mouse. I already checked.
Every time I depress the clutch pedal the clutch squeaks. It is not the pedal itself, it is from somewhere under the car. The squeak is comical in nature, sounding like a dog's squeaky toy.
If you have seen the movie "Snatch" it sounds like when the dog eats the squeaky toy. Kinda wheezy and just hilarious. But I have no idea what would be causing it.
I initially thought (after the mouse idea) it might be the throw out bearing, but I had a friend check it out and he didn't think that was the culprit. Might still be the problem, but I have no idea to be honest. In my illustrious 8-year history working on Nissans, I have never encountered this problem.
I should add the clutch works perfectly. Grabs hard, has never slipped, and pedal feel is normal. Truck is a 98 Frontier XE 4x4, 123k miles, ka24de.
Perhaps the clutch fork needs greasing? Maybe my master cylinder (or slave) is trying to tell me its on its way out?
I have no clue. Please share your thoughts.
Saudade
My only thought is you should have someone else depress the clutch while you crawl around underneath to locate the "mouse". There's not a lot of moving parts so it should be easy to trap. (pun intended)
OK, so it's not my only thought but I can't mention some of the others here.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I have to agree, look under the truck while someone cycles the pedal for you. That's how I found my e-brake squeak.
PEZi
LAWL!!!!
rizzobc
Car: 1987 nissan hardbody
"What do I know about Diamonds"
"Are you telling me porky pies"
"I don't want that dog dribbling on my seats. Your seats? Tyrone, this is a stolen car, mate."
nos487
Car: 86.5 nissan V6 5speed truck
I found a couple of times the ball the fork pivots on gets dry and squeaks.
moneymike
Car: 1991 nissan d21 hardbody
chances are if it squeaks only when its depressed its got to be if not around the throw out bearing
RT22
Car: 1991 nissan hardbody
Mine does it now and then, a little oil on the linkage under dash and on the seal on firewall shuts it up for a while.
Q451990
My '97 had this squeak on the lever that's pushed in by the slave cylinder. I could spray that area down with some lubricant and quiet it down for a while, but eventually it came back... might have been using the wrong kind of lube though.
Heath
Fisherdude
Car: 1996 Nissan Pathfinder 4x4 SE
My 96 squeaks after i changed the slave cylinder
