ken240sx »
https://forums.nicoclub.com/ken240sx-u27409.html
Sun Jul 06, 2008 7:39 am
Here's what I've experienced...When just diving normal you should be seeing 14-16's for your afrs, if you let off the throttle a little, it will go to the 17-20's area for a second, then go back down to the 15 range again. If you're giving any kind of acceleration throttle then let off, it should dip really quick into rich then pop up into the lean for a second then even out. When accelerating, even slightly then letting off, it is still giving some gas, so it will run rich for a split second...you may n ot even notice it if you aren't looking, then the fact that the throttle plate is closed abruptly and cuts air off sharply it will go lean on you until it reacts and then goes back closer to stoich. any time the air is cut off somewhat sharply you will go lean. It is like this on all of the stock vehicles w/stock ecu's that I've hooked up widebands to. The 240, acura TL, escort, neon, camaro, saab 9-3, another 240, talon, and the list goes on. I don't think you have anything to worry about, as long as your afrs are under the 13's under acceleration you should be ok.
