why does my car pull to the right when i brake or let off the gas.
A home for 1983–1989 300ZX owners!
seulatr97
Car: 1989 nissan 300zx n/a
why does my car pull to the right when i brake or let off the gas. i pulled the tires off it has brand new pads on it. could it be alignment or the rotors. i just started see hot spot when i step on the brakes starting to shake. but not all the time.
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
seized caliper on the right side is my guess
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
Moved your threads for you to the proper forum and eliminated the poll options as they're obviously not polls.
seulatr97
thanks
seulatr97
if it was seized how good i drive. it only pulles right when i step on the brake. i don'[t think it is seized
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the left calliper could be siezed open so only the right clamps thus pulling to the right, could also be an alignment issue, but lets start by verifying each wheel brakes when you hit the pedal and releases when you let off, jack up each corner and have a friend step in the brake while you try to turn each wheel and then release and verify they all turn freely
seulatr97
i do that first thing in the morning didn't think aobut that.
zzee
Car: 1984 300zx turbo
Break vac booster issue possibly.
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
seulatr97 wrote:why does my car pull to the right when i brake or let off the gas. i pulled the tires off it has brand new pads on it. could it be alignment or the rotors. i just started see hot spot when i step on the brakes starting to shake. but not all the time.
If it also happens when you let off the gas, its most likely an alignment problem.
Pharaohabq
Car: 92' Nissan 300ZX NA
AZ-ZBum wrote:If it also happens when you let off the gas, its most likely an alignment problem.
Yeah Alignment problem or maybe a bad tie rod bushing that might cause it to pull too. Any shudders or noise while driving?
Phar
wantz87
Car: 1990 240sx/stock v2.0
1998 GMC Sierra c1500
if it is shaking, there is most likely excessive run-out in the rotor, possibly from machining improperly or from heat soak and pinching the rotor. and as far as the pull, check the front right caliper assembly and both rears, cars pull toward the front caliper that works the most, and the rear that works the least. if it was an alignment issue, it would happen no matter what the throttle position is:tut . unlikely but also possible is slop in the suspension arms. when there is a rearward force it pulls the linkage into the correct position, but when the weight shifts forward it could move the arm to create an unwanted angle to cause the pull.
Return to “300ZX (Z31) Forum”
