Why does my car do this?
A home for 1983–1989 300ZX owners!
winez31
Car: 1993 s13 ka24de
so today i drove my car for like 45min straight, and when i got home i forgot to let my car cool down. then when i came back out of my house and tried to leave it wouldn't stay running. so i left in my other car and let it cool off and now it runs fine. does anyone know what causes this?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
when the car won't start, will the engine turn with the starter? or do you get nothing when you turn the key?
winez31
it will like start but won't stay running and it runs really rough. I tried to drive it it would stutter up to 5 lbs then take off like it normally would from 5 to 10lbs.
winez31
bump it did it again today
evildky
06 Nissan 350Z GT
I'd suspece the AMF or the connector, a litte die electric grease in the connector is a good idea, and so we're clean at vacue the car won't hardly run but once you get up to about 5 psi o boost the car runs good?
winez31
yeah i tired electric greece still not working. i looked at the ecu and its not throwing any codes. i have no idea what it is.
winez31
update: it only runs bad whe it warms up and i still have no idea what it is.
evildky
06 Nissan 350Z GT
CHTS? but I don't think it would casue ti to run that badly, or perhaps the IAC stuck open so it can't stay running at iwarm dle?
winez31
nope it dies right away do you have aim its easier to explain on here
winez31
i think its because i crushed my fpr to much
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
winez31 wrote:i think its because i crushed my fpr to much
Umm... Just what were you trying to accomplish by doing this?
evildky
06 Nissan 350Z GT
DOH! you did the turbo dsm fuel pressure in a vice trick and then the trouble started!? then yeah your flooding the thing, time for a new fpr
winez31
yeah, thats what i was thinking, but then someone told me it could possibly be vapor lock.
evildky
06 Nissan 350Z GT
if the problem started when you crushed the fpr, then you should have no reason to look for any other explanation, which depending on the amount of pressure, which I am gonna guess is pretty high you could be damaging your fuel pump, too much back pressure will cause the pump to work a lot harder and shorten it's life, I suggest you pick up a decent AFPR, I have the aeromotove on my car but unless your getting into the 14=20 psi range I think the less expensive bosch should suit your needs
AZ-ZBum
winez31 wrote:yeah, thats what i was thinking, but then someone told me it could possibly be vapor lock.
It's VERY difficult for a fuel injected car to suffer from vapor lock. There's usually too much fuel pressure. You're flooding your engine. It's also possible you've broken the internal seal in the FPR and are dumping raw fuel into the intake plenum via the vacuum lines.
winez31
ok. thanks guys thats what my guess is to. today i drove it and once it warmed up it ran really bad, and once it hit boost bluish white smoke poored out. so im guessing im running extremely rich.
winez31
so it wasnt fpr i replaced it today same thing once my car warms up it doesnt stay running
AZ-ZBum
check your plugs. My guess is you've fouled them so much they may take time to come around. Or just put in new ones.
winez31
i just replaced them yesterday. the ecu is thowing a code for a neutral switch?
winez31
i just don't understand why it does it when it warms up. it now sounds like a constant back fire
evildky
06 Nissan 350Z GT
white smoke indicates burning coolant, lets hope you don't have a blown HG, have you messed with the timing? does it backfire all the way through or only under boost? if the timing is retarded too far you'll be burning the charge as the exhaust valves open, I've also seen the optical distributors fail intermitantly which can casue a similar issue, did the plugs look fowled or did they look hot? just wondering if it couldn't be a fuel pump that can't keep up but they tend to be problems under boost not at idle
winez31
it runs fine all the way throught till it warms up and after it warms up till boost hits 5lbs idk. im starting to wonder if my timing belt skipped a notch, but wouldn't that affect it even if it was cold?
winez31
ok... so heres what i have replaced chts,fpr,plugs,all my vacume lines,thermostat. and still it runs till till the first line on the temp gauge then it dies. next im gunna try ecu
winez31
the plugs just smelled like straight gas and they were black
winez31
bump im getting really upset
AZ-ZBum
Wow! You're an impatient bastard, aren't you?
You're getting too much fuel. Figure out why. Bad injectors. Bad fuel pressure. Bad ECU. Bad FPR. etc.
winez31
yeah very.
winez31
ok so now it won't even rev to 1200rpm and it sounds like it misses right away when i start it now. so basically it is getting worse the more things i fix.
evildky
06 Nissan 350Z GT
hows your plug wires? I had a bud with a escort that behaved similarly and he heven replaced the wires twice before gettng a set that fixed the problem? could be a MAS issue? AICV? Fuel pump? these are the things I would look at?
winez31
my fuel pup seems to me fine im gunna try a new ecu then maf. thanks for your help guys i really apriciate this im going through z withdrawls.
Return to “300ZX (Z31) Forum”
