why does my caliper keep leaking fluid?
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
the original caliper on the rear right side leaked, so i borrowed a friends and it worked for a few days...not that one is leaking as well..whats the deal here, just two bad calipers? it worked fine on his car though? i have one more laying around but is it just the calipers are old and s***ty, or is there something else i should be looking for?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
bad used old calipers or the line itself is leaking. At the threads banged up?
Perhaps rebuild the rear calipers and replace the lines while your at it.
Warped161
Car: 90 s13 the never ending project
Can you tell where its leaking from? Did you install 2 new copper rings on the bolt that goes through the brake line to the caliper?
sjbsuperman1425
CA18DET
Warped161 wrote:Can you tell where its leaking from? Did you install 2 new copper rings on the bolt that goes through the brake line to the caliper?
it looks as though its coming from the piston, but the bolt for the e-brake bracket is a little wet..its raining right now i can't tell for sure. i also didn't take it off yet as i was really frustrated..but no i used the old washers, could it just be those? maybe take the line off and clean them? yes the threads are all good on it.
Modified by sjbsuperman1425 at 8:23 AM 3/29/2009
sjbsuperman1425
CA18DET
upon closer inspection both rear calipers are leaking..i dont understand this, they worked fine for 5 days and just decide to leak out of nowhere?
sjbsuperman1425
CA18DET
well im just going to go buy reman calipers from Advance Auto...they are $150 for two and have a lifetime warranty on them..
but would pulling the e-brake up with no fluid in the calipers cause the piston to wear on that seal and possibly destroy it? im wondering because BOTH sides went out on me at once, and not the front ones..thanks.
rico05
Car: 1992 RMS13 w/ CA18DET
I have had both rears go out. No warning. Just walked out to a puddle of fluid. Me thinks it may have to do with the constant pressure of the ebrake flexing the seals more than the fronts. Just get new ones and move on.
sjbsuperman1425
CA18DET
yea something like that...i guess i'll just have to start putting it in gear when im done driving from now on
