cholojr19 wrote:what happens if you dont recirculate the blowoff valve? in other words do you need to?
you'll experience problems like:-poor on/off throttle response when the bov has opened (after boost).-if you lift the throttle after full boost and coast to a stop, the engine goes rich from releasing the metered air it is expecting. This can cause the engine to stall or get near stalling. If you tighten the bov enough, the SR will run ok.-you'll get backfire and popping in your exhaust, guaranteed.-you'll risk fouling spark plugs much easier-the excess fuel from the atmospheric bov could also melt your catalytic converter and clog it. Some people with atmos. bov's prefer to run a test pipe instead of a cat.
I recommend recirculating, it does make a big difference with performance.
Modified by Luke at 1:46 PM 4/27/2005
