KEMP »
https://forums.nicoclub.com/kemp-u119247.html
Wed Mar 25, 2009 6:12 pm
feed line is a full stainless line with a not restricted feed plate on the turbo, the oil drain is damn near straight and has no kinks, its hard rubber hose with an puck fittings, there is no bends in it, the weird thig i, it just started smoking last night really bad, so i swapped the turbo and it kept happening, but my turbo was toast, shaftply and oil leaking out of both ends. the "new" turbo had like no play and now it does have a little with still smoke, the amount of oil in my intecooler lines was quite a bit, i would definetly say enough to feed the intake plenum and burn oil with the gas mixture, the oil coming out is burnt smelling, and there is literally oil in my exhaust tip, i can wipe my finger in it after driving and it has oil in it.
any other suggestions? and should i use a restictor on my turbonetics that im getting?
the compressor side of the turbo went on with a clean inside, and came out with oil on the inlet and outlet of the compressor, with oil, the inside looked like it caught on fire it was so black from the oil, lol
and its not crankcase vent, since its going to a catch can.
