i dont think the V is for the engine configuration (although im no expert) but waht about my QR25de? how is a Q a configuration, or the RB, what is R?, i *think* the vg is just the engine famiy, just like RB, SR, QR , so on and so forth, the 3o is obviously for the 3.o liters of displacement and the E is for single over head cam, as already mentionedmiteymax86 wrote:V- for engine configurationG-no idea, just internal engine family designation I thinkE=SOHC
McAdam wrote:actually, if you wanna get technical....
VG is the engine family.30 is for the displacement E is for Electronic fuel injection.
there is no notation for SOHC, its just assumed. there is notation only for DOHC, as in VG30DE. the only special case would be the FJ20ET and FJ20E, where they were nissans first DOHC motors and the only ones (to my knowledge) that did not get the D notation. also, if you see VQ30DD, one D is for DOHC and the other is for Direct Injection.
McAdam
Not many have done turbo setups on a VE. There are no dyno figures sadly.Some VQ's are pushing 350FWHP so it's possible the VE can do the same.VE has the same bottom end specs moreso with the vg30et than the vg30e-there are slight differences. Crank,rods and pistons from a vg30et will fit. But the head CC must be different from the VE so compression may change. I tried to get lower compression pistons from JE,Wiseco,etc...none of them knew what a VE30DE was. The FSM doesn't supply enough information to give them.As for a transmission, I never heard of someone installing a rwd transmission on the VE. But, The VE transmission will fit the FWD VG30E, The RWD VG30ET transmission will also fit the VG30E. That should mean they all are interchangable. Mounts are different from the FWD vg30e, but they bolt to the same location.McAdam wrote:hey 93 maxse>>> some questions for ya about the VE30DE....
any idea how much HP this motor can hold in turbo applications? can it be converted to RWD? do VG30E parts interchange? such as transmissions, mounts stuff like that?? time for a very perverted 240sx swap......
McADam
nlzmo400r wrote:well then if you're info is correct it doesnt sound like itd be TOO insanely hard, but keep in mind, the vq has .5 liters over the ve, so a 35ofwhp vq will be easier to attain than with a ve,
nlzmo400r wrote:ok, i got a lil lost by your last post, i didnt know of any VQ3o, the only vq i know of is the 35, the older maximas had hte vg3ode correct? please correct me if im wrong, and yes i agree that the vg shouldve came in the 24o, but then you'd have a 3oozx, also, are the vg3o and ve3o not the same motor, i never heard of a ve3o before
pcbootleger wrote:q=cache:CcVWiOd4yeIJ:http://www.usedenginesplus.com/Nissan/nissan
pcbootleger wrote:found these cool sites: http://www.freshalloy.com/site...shtml
http://216.239.53.104/search?q=cache:Cc ... om...UTF-8
that should explain all the nissan engines. still lacks some info but still good none the less
if you can find a better site with all of nissans engines with ALL of the needed info, please let me know. I would really be interested. Or if someone could make a site that would freaking rule.
That list is for Nissans engines in the Asian market. There might be differences in the way the hp was calculated. I know that in some markets the power is reported in kilowatts and the conversion to hp might affect the numbers.pcbootleger wrote:sweet list. but they got a lot of the horsepower wrong for most cars. even the ones that are under 273. I know for a fact that my car only has 160 hp and the turbo model only comes with 200. so is like Prince before datsun or something? Or was this like an old version of infiniti?
