Neil »
https://forums.nicoclub.com/neil-u15642.html
Mon Oct 06, 2008 12:11 am
They sell them because they realize they made a mistake in assuming they are worthy tuning tools.
An AFC works by directly altering the MAF voltage. Ignition timing is determined by engine load, and engine load is calculated via TPS and MAF voltage plotted against RPM. Therefore, when you alter the MAF voltage, you artificially advance or retard ignition timing, and that's why they're dangerous, and unacceptable (in my opinion) as tuning tools. There's no sense in "adding" a little more fuel if you don't know what the ignition timing is doing, and ignition timing is what can make or break a tune (or your motor).
An AFC is not much more than ricer chic'.
As for the other half of your question, unfortunately neither the T25 or stock 370cc fuel injectors are capable of supporting much more than 12psi. If you set aside $1500 you can get an S15 GT28R turbo, 550cc injectors, Z32 maf, rom-tune and gaskets/hardware/etc. That's a popular and cost effective way to be easily able to turn out close to 300whp all day.
Modified by Neil at 1:28 PM 10/7/2008
