Why do my Wisecos have "FWD" etched on them?
toki
Yeahh bought a set of 9:1 KA24DE wisecos, opened but never used, part number is k586m895 which is listed as for the 95-98 KA24De .5mm over....but it has FWD etched in the cylinder face for some reason. Anyone know why? More specifically, if there is any perticular reason, is it going to impede me putting them in my SOHC as planned (yes im aware the compression drops to 8:1.)
slide240slide
Car: 1991 Nissan 240SX KA motor 5-speed
is it stamped toward a outer edge of the piston? Most pistons have a mark indicating which side faces the "front" of the block, because you can get the pistons on the rod wrong believe it or not. but it seems they would have marked them "FRT" instead of "FWD" i would just E-mail wiseco and ask their Tech support.
BadMojo
Car: 2007 Mazdaspeed 3
slide240slide wrote:is it stamped toward a outer edge of the piston? Most pistons have a mark indicating which side faces the "front" of the block, because you can get the pistons on the rod wrong believe it or not. but it seems they would have marked them "FRT" instead of "FWD" i would just E-mail wiseco and ask their Tech support.
Just guessing here, but I'd imagine the FWD is for "forward", as in facing towards the front of engine.
toki
they all say FWD, all in the same location close to a dimple on the perimeter on the face where it becomes flat (As apposed to dished.)
95_240sx
Car: My baby (car)
Wow, mine have always said RWD on them.....
Haha just kidding, Ive been wondering that too.
Rick
MarkEmark
Car: fully-built '95 240sx KA-T
toki wrote:Yeahh bought a set of 9:1 KA24DE wisecos, opened but never used, part number is k586m895 which is listed as for the 95-98 KA24De .5mm over....but it has FWD etched in the cylinder face for some reason. Anyone know why? More specifically, if there is any perticular reason, is it going to impede me putting them in my SOHC as planned (yes im aware the compression drops to 8:1.)
Off topic, but where did you get your wisecos for, and how much, and what kind of rings did you get with them? reading wiseco's website, there's apparently different rings offered for the same pistons...
N.O. Accorderz
