Yes float, I found that thread along with your comment:
I mention this because I tried finding one at a local parts store and they could find any item by the name of "dropping resistor" is there another name? I looked for it under the two models of eclipse and talon 2.0 liters turbo, and the guy at O'Reillys couldn't find it."by float_6969 » 11 Mar 2007 15:11
Quote Source:
dsm-resistor-ca18det-t194177.html
This is for using a DSM resistor pack on the CA18DET. AFAIK, any 1st gen eclipse/laser/talon should have this resistor pack.
Also, while searching I found this thread (below) explaining how to hook up resistors to basically do the same thing the dropping resistor does. In the threa he mentions to use resistors which have an 8 ohm limit, does this mean that a stock CA18det should have the sane 8 ohm resistance? Inferring so, i will be looking for that "golden" number 8 on my ohm resistance test. (Using a multimeter is pretty new to me, I'm sure it's apparent)
http://zilvia.net/f/archive-faqs/133034 ... roved.html
