ok, i havent been on in awhile or spoken much but..... i do have some things to say about this thread.........
mtzgr777 wrote:My father replaced the knock sensors on his '02 Maxima for $1400. Have yet to feel a difference at all. We think the card reader at the dealership was either rigged or faulty. That is why I'm going to wait to see if the SES light comes back on. (It hasn't in 15 miles of driving.)
did u reset the ecm???? to be simple.... its in retarded mode so u dont kill it!!! it is smart enough to know to save itself, & also 15 miles isnt long enough...... so pull the ecm fuse(s) for awhile...then see waht happens. it can relearn that its not dead & can advance timing to where it belongs or better . u probably didnt but do that & drive it like u stole it... it will make a difference..... as long as everything else is working correctly.
qship96 wrote:
Faulty defective knock sensors WILL NEVER CAUSE the engine lamp to illuminate, it just silently stores a fault code in ECU.
iwill have to disagree with u on that, older non OBD2 yes, new no. it is a emissions problem for those that have tests 7 without test, still if i doesnt bring it on the light it still has a code & its a expensive fix to make EPA happy...... to epa measures it has not finished drive cycle &or light on... will fail test. & more then not, i have cleared codes on many nissan & gm trucks for knock codes, which are common & they still, light comeback on right away
& how did we get from the oem subject thread at hand to this...... mine at 175k is clean.
i would use BG products only...... not to sell, they actually work!!! just not for anything else find a good shop that does FI services... intake clean,injector, & intank stuff. this all cleans everything top of pistons, ect. the shot so to speak.
i wont start with the others of the GM & Dodge topic.....another thread plz
