steve s14 wrote:depends on what you would consider sophisticated. they sure didn't have even remotely close to the computer aided design capabilities they do now.
steve s14 wrote:notice how much stiffer the chassis on an ... (SNIP)
Uh, re-read my second post and note the presence of the word "engine" not chassis. Let's focus shall we? (Though you should be informed that the practice of using computer based modelling goes back to the, gasp!, 'unsophisticated' late 1970s. Indeed, at work we stopped physically modelling frames in the R&D stage altogether as our computer models are cheaper, faster and if configured correctly more accurate. But our physical models are VERY sophisticated by any standard)
steve s14 wrote:so as far as [engine R&D] being "sophisticated for decades". i'd have to disagree.
Your response suggests that you have neither a background in nor an appreciation of the historical evolution of the IC engine. This ignorance of engineering history makes your response, in my opinion, particularly arrogant in it's implied bias that modernity equals sophistication.
steve s14 wrote:no where did i say that 170 is where the engine temps should be for proper operation.
Oh? Actually you did pretty much say that. And I quote "probably because the engine runs better that way". :nono :nono :nono Obviously the context of "that way" in the thread is referring to 170F topic. As was noted by another poster - the engine's internal water temperature is indeed similar to other engines and the lower tstat is merely a function of the difference in location. We were both in error in overlooking that fact. You merely compounded upon the erroneous presumption by assuming it 'probably runs better that way'.
steve s14 wrote:i was speculating that the person or persons that designed the engine 17 plus years ago, knew what they were doing.
Just as they knew what they were doing 25 or 50 years ago.
