Carl H wrote:^ tru.but also consider the size of the engine...an sr spining at 5krpm is not the same as a vh spinning at 5k rpm.like everthing of the era i think nissan wanted to make sure that it would function properly even if it was outside of its 'design limits' for induction...i mean after all if the stock maf can read 400+whp then what else did they do?
The engine was clearly built for endurance racing from top to bottom, IMHO. I have been taking one apart this last week, read the SAE paper (which doesn't cover half of it), etc. I want to see what one of these will do at 30 psi and 8krpm with built internals. I've no doubt the block and crank will hold whatever you throw at it.
The throttle is designed to allow for an intake size that doesn't require the air tract to taper up excessively as the air flows into the intake manifold.
