!!!! low pressure single turbo? i mean with that kind of power, maybe there can even be a way to reinforce the cvt. stronger chain/belt?adidas2go wrote:Were, not sure yet, but Im about to prove to disprove the theory that the CVT is weak. Putting 400 horses into it should be a good test
my dad works for a company helps build the fluid and worked with nissan hand in hand to create this - CVT's are built for the long haul and aren't meant to die at the 100,000 mark like some auto transmission's do. CPS is right in the fact that a CVT flush is much more expensive than a normal auto transmission flush but well worth it in the end. (on a small side note the CVT fluid [N-2] is actually meant to withstand up to 75,000 miles, so if you miss by a scheduled maintenece by a few miles, you're fine).CPS wrote:Every problem I've seen with a CVT has been fluid-related. We are actually discussing this under the Murano forum on this site. The CVT fluid acts as a barrier to prevent excessive wear, but people always balk at the price it takes to drain and fill the CVT fluid. $200 now or $5000-6000 down the road?
Good info! Thanks!marlin29311 wrote:my dad works for a company helps build the fluid and worked with nissan hand in hand to create this - CVT's are built for the long haul and aren't meant to die at the 100,000 mark like some auto transmission's do. CPS is right in the fact that a CVT flush is much more expensive than a normal auto transmission flush but well worth it in the end. (on a small side note the CVT fluid [N-2] is actually meant to withstand up to 75,000 miles, so if you miss by a scheduled maintenece by a few miles, you're fine).
