Im trying to get a lower boost not a higher boost.... and to stay steady. Is there somethign im missing here because peoples use mbc and seems fine except few like me. ANyone thats experience give the brother a hand........thanksBaliLover wrote:If you are experiencing overboosting, you should know that MBC do have a habit of allowing boost spikes that will go beyond what you want when the turbo spools.
If you are trying to get more than 15psi with it, good luck. Every MBC I've ever played with had trouble maintaining much above 12psi
Well, its hooked up to the stock rubber intake?Luke wrote:Did you say you hooked it up from the wastegate to the "intake"? It should be connected to a boost pressure source, like the hotpipe.
