If I was going to do it with the oil pan on the car thats the way Id do it.Florida240sx wrote:Best thing is to have oil in the pan. Put vaseline over your drill bit and slowly keep getting bigger in size. The vaselien should catch the shavings as hey come off. What falls inside goes into the oil, which when you drian it most should be gone. Get a oil plug that has a magnet on then the end.
I'd steal a lift and do it that way, it will take alot less work and be cleaner. Just make damn sure to mark where(your return) before you pull it out. Again I didnt unbolt shyt to do mine, BEAT A WHOLE AND MADE THE FITTING THREAD INTO IT. JBWELD OR RTV SEALANT AROUND IT< DONE its a mustang trick IIRC thats where I saw itFlorida240sx wrote:Wait...Your doing a transmission swap? Yank the whole thing out. Do your trnany swpa oil pan clutch etc. Prep the engine for turbo
