Why can't I boost higher than 9 psi?
Silverbullet91
Car: 1991 240SX SE Coupe w/sr20det redtop
Hey guys whats up. I was driving to work this morning and when I got to the freeway on ramp I noticed I wasn't making more that 9 pounds of boost. I have been running around at 12 psi. What gives? I've got the stock t25 on my redtop with a manual boost controller. I did a quick look over in the parking and couldn't find anything obvious. Even turned the boost controller up a little-didn't really make a difference. Other than that the car drives great, no hesistation, no smoke, no funny noises, etc. Anybody got any ideas on this?
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
What kind of boost contoller is it?
Silverbullet91
Hey man, thanks for the response. I appreciate it.
Its a DNA manual boost controller. Like I said its been on there a couple of months @ 12 psi. It was even fine yesterday. Hope my turbo is not getting ready to die on me. $$$$$
NIGHTfall_240sx
Car: Nissan S14 [notchtop SR] SOLD
weather can effect your boost levels.
i remember ona hot day i was boostin 12psi, and with the exact setting on my controller (34%) on a cold day i was hittin 15psi? (around there)
jr_ss
Car: 95' S14
You could also have a vacuum/boost leak...
Silverbullet91
Your right nightfall; Weather can have a big effect on a manual boost controller. But I went from 12 pounds to 9. Overnight. Colder air is more dense and will often have you making more boost. And it wasn't exactly 100 degrees yesterday. Besides it was making the 12 psi in the summer heat so thats not the problem.
Also if I had a boost leak I would think the car would be sputtering and bucking and skipping all over the place. And if there was a vaccum leak say like to the wastegate actuator would it just want to stay closed and make more boost instead of less. I freakin out here man!
bdrifta
Car: 1992 Nissan 240sx sr20det
are you running a stock bov...because my car did the same thing...and i built a pressure tester for my system, and it was my bov, it leaked under boost, but not vac. I replaced the bov, and now its perfect.
Silverbullet91
No, I'm running a greddy type rs bov and greddy front mount. I was planning checking for boost leaks this weekend but I just got home from work and looked under the hood in the daylight and what do I find...the hose I used to recirculate my bov is covered with oil. No!! Time to take a look at the shaft play. Also, now I think I might be hearing some faint metal sounds just as the turbo is to starting to spool up under light throttle. I haven't even put 3,000 miles on this motor since the swap. I'm getting some beer...
luv2spedup
Car: 89 silvia
yep check for leaks and keep us posted
Silverbullet91
I'll keep this up to date, but it might be a while before I have something new to say. I'm having to work on my girlfriend's car this weekend (a whole other story) so my schedule is kinda full. I've just parked my car for the moment.
