Thank you again for the education and the resources Vstar. I've downloaded a copy for my files.VStar650CL wrote: ↑Sun Apr 07, 2024 1:38 pmThere's no '91 FSM here in Nico but there is a complete '90, see FA-5 here (pdf page 1047) for the front end torque specs:
https://www.nicoclub.com/service-manual ... k_1990.pdf
Nissan puts almost all their torque specs into the exploded drawings. There's a legend at the bottom of the diagram, lbs/ft is the second number in parens. So your Haynes is correct, the upper is indeed 58~108 and the lower 87~108. For ball joints the only concern is having the tapered shaft fully seated into the tapered hole, so in practice the absolute torque doesn't make much difference as long as it's "tight enough". The same is true of almost all tapered front end parts.
hahaha I get it. Well I've learned something new out of this process. Thanks again VStar!VStar650CL wrote: ↑Mon Apr 08, 2024 6:13 amShock bolts are a little different for reasons I expressed in your other thread, but it's the same in one way, which is that in both cases, there's almost no dynamic load on the fastener which would tend to loosen it. With a ball joint or tie-rod end there's zero turning force applied to the nut as long as the ball doesn't bind, for a shock retainer with a transverse eye, almost all the applied force is perpendicular to the bolt or stud with no rotational component. So in both cases the torque spec is likely to be wishy-washy, simply because no engineer wants to put "tight enough" into a service manual.
