911/Q45 wrote:I think the factory disabled the TCS to get 5.9 0-60. You need some wheelspin to get into the power range quickly, especially with a heavy car.
Car and driver is the one that got 6.0 0-60 and road and track had slower numbers.
Some of the early made '02's had a gas pedal fix (tsb) that removed a spring from the pedal that caused delay before the car would go. When I had my car in for the 3,750 service, they updated my pedal to the newer version, and it's more comfortable than before. Now when you press the gas, the pedal moves the bar behind it instantly. Before, there was about a 2 inch gap before it would actually move the pedal. I can't really tell if it's any quicker.
I was also imformed about a new TSB that came out about 3 mo nths ago. It invloves adding a new TCM transmission control module for quicker acceleration. He said it made a big difference and the car reponds instantly to the gas. I'm having this done on my next service.
The 03's model gears have been changed which will give .3 seconds faster 0-60, but that will lead to worse highway gas mileage. The reason the gears are where for 2002, was to achieve better fuel economy.
Another thing that most testers of the Q havn't done, is to TURN off the VDC BEFORE TESTING! VDC limits wheel spin and also hampers launch when mashing the pedal from a start. If you keep VDC off, it does leave the line quicker. The car does MOVE.
This is 0-70mph with VDC off.
nyes road mpg
Pay close attention, right after it shifts into second, it's almost at 60 mph. 60 mph is the third mark up from 0.
After you hear it shift into third, that's 70 mph.
